Posted by ScottyHOMEy on September 05, 2007 at 18:36:42 from (71.241.196.242):
In Reply to: Farmall B-oil and water posted by Dave H (MI) on September 05, 2007 at 17:44:55:
Ah-hah! One culprit found. That baby's been dry for a while.
It wouldn't really do much to reduce humidity in the in crank case, but the rust is a sign of neglect.
To take care of a lot of rust (and especially the kind of rust that is in the "fleece" on that breather cap) I use a product that I found at Home Depot. The brand is Jayco, comes in a cylindrical quart plastic bottle, contents light green in color and can be found in the paint section.
It is a dilute phosphoric acid. The idea is that the acid reacts with the iron oxide and converts it to iron phosphate, which is less susceptible to rust in the presence of moisture. Kind of like the concept of bluing on a gun barrel -- already rusted, just not to make that nasty red iron oxide, and resistant to rusting any further.
You could probably get by with just filling that cap with oil and letting it drain, and the oil left will do the job as the whole thing was designed to do, perhaps even better by virtue of the increased surafce area resulting from the pits!
For small bucks, I'd blow it out with an aerosol solvent like brake cleaner to get rid of whatever crud it has already caught, put the phosphate to it, rinse it out with water, and let it dry before filling it with oil and letting it drain and reinstalling. You could easily skip the acid part and be just fine --use a solvent to clean it out, bathe it in oil and let that oil drain out.
It works a lot like the updraft section of the oil bath air cleaner in that the oil in the "wool" of it traps any dust that might try to pass by.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
