Re: Worm gear oil?
Posted by Jim Becker on September 06, 2007 at 21:21:23 from (71.123.189.4):
In Reply to: Worm gear oil? posted by mpjrichmond on September 05, 2007 at 19:23:42:
90 or 80w90 gear oil is fine. If it leaks out, fixing it so it dioesn't leak isn't that big a deal. Using grease pretty well guarantees that the upper bushing will never be lubricated.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
