Hitachi is charging!
Posted by Tired 300 in Mn on September 07, 2007 at 08:03:16 from (64.61.224.148):
Thanks so much, I had a small toggle switch from which I ran a 16 ga wire to the L terminal. With the engine about 1/4 throttle I have 14.3 volts at the bat terminal on the alternator. Is this an OK setup or should I replace the switch with a bulb or resistor? Thanks again. Sonny
