Re: Diesel start on gas engines
Posted by Doc Larry on September 07, 2007 at 20:35:09 from (216.146.101.227):
In Reply to: Diesel start on gas engines posted by Dave H (MI) on September 07, 2007 at 10:25:47:
Dave,
I'm a little confused by your positive ground. My '49 TD6 was 12v negative ground. At any rate, the starter on mine would bind up from time to time, and when that happened, I had to loosen up the starter mounting bolts to get it unbound. But sounds like you have bigger problems than that. Or, more fun ahead, if that's your perspective. I like to rebuild engines if I'm not rushed....
Larry
