Re: Is there a way to check a light control?
Posted by Janicholson on September 08, 2007 at 07:10:44 from (66.173.50.72):
In Reply to: Is there a way to check a light control? posted by Mike CA on September 07, 2007 at 23:43:58:
Dear Mike,
Use the cover with the best finish. The one in the picture with the galvanized pip in front of it is better than the other metal, just switch the meters from on to the other.
There will be one wire coming from the amp meter and going to the fuse (on the switch), then to a switch terminal (may have no screw,just a tab of metal connecting the fuse) built in to the switch. It is power in.
All other terminals with screws are output terminals.
Each should conduct (be connected) to the power in when the knob is turned from one position to the next. There should be a wire wound resistor on the back on the switch between two terminals. this is the light dimming resistor, and measures in the area of 1.5 to 2 ohms across it.
If you intend to put this back to correct police correct, and the generator is a three brush with cutout relay, then it needs a light switch that has 4 positions LHDB
Low charge, High charge, Dim lights and bright lights. This switch will have more terminals, and it will have two resistors, and some terminals will be ground terminals to the body of the switch! Good luck, JimN
