Re: injector pump 350 diesel
Posted by georgeky on September 08, 2007 at 09:21:04 from (64.12.116.73):
In Reply to: injector pump 350 diesel posted by tractor dan on September 08, 2007 at 02:37:20:
Out.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
