Posted by Janicholson on September 08, 2007 at 16:55:40 from (66.173.50.4):
In Reply to: Farmall WD-6 posted by karsky on September 08, 2007 at 16:47:24:
Several things can make that happen: The ground switch on the manifold that shuts off the mag when in D mode could be disconnected, or broken, or not being moved. The linkages that operate the starting valve might be jambed (If it will not crank fast or at all suspect this) The plugs may be fowled and not sparking. Have you choked the devil out of it to get it to fire? some take extreme choke and rich fuel to run on gas. Is the mag in time? Will it fire on ether in the gas mode (do not try this on the D mode!!) is there a steady stream of fuel to the carb? Good luck, Keep us aware of the progress. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
