Re: Roll call of projects in the works.
Posted by Clarkbug on September 09, 2007 at 05:44:27 from (72.83.165.199):
In Reply to: Roll call of projects in the works. posted by Tom Windsor on September 08, 2007 at 19:59:30:
Hmm...lets see. My '49 M needs....
- New rear tires
- One axle seal
- A coat of paint to keep the rust away
- Carb/Governor need to be adjusted
- Starter started smoking last time I ran it, so thats something to look at
- Repair one brake cover (bolt/threaded boss is torn from the bottom of cover)
- Wont stay in 5th gear under load
- Change rear differential oil
- Take off the #5 mower for the season
Then I can work on figuring out why my uncles MF 135 wont charge the battery, and installing an electronic ignition in our MF 35 Deluxe.
Its too bad all those tractors are in a different state than me.
