Re: Roll call of projects in the works.
Posted by teddy52food on September 09, 2007 at 07:19:46 from (204.73.107.177):
In Reply to: Roll call of projects in the works. posted by Tom Windsor on September 08, 2007 at 19:59:30:
I need to put a brake lining in the Farmall B. Then get it ready to paint. Have a F12 soaking in the shed. Just got a head back on the brass tag us JD B. It runs good now. I , am finishing up on another F12, should get it done this winter. I have a 44 JD B that needs radiator removed & repaired. A friend of mine has a shaft to build up & turn on the lathe and a generator to fix. Snowmobile trailor needs a new deck & maybe new tires ,wheel bearings repacked etc, lites checked before deer hunting. All this & I am disabled. It seems like I work twice as hard and only get half as much done.
