Posted by Janicholson on September 09, 2007 at 12:09:01 from (66.173.50.102):
In Reply to: Rusted bolts posted by Mike CA on September 09, 2007 at 11:58:58:
The clamp bolts can be removed by splitting the nuts. Take apart the light to prevent breakage, and put the bolt head on a steel surface (like the draw bar U) so that one of the flats of the nut is flat on the metal. Use a sharp cold chisel and hammer to split the nut in the direction of the bolts centerline. The flat is the closest point to the threads, and as you repeatedly hit the same mark (be careful) the nut will swell and release the pressure on the bolt. No problem. Have someone hold the light so that the person with the hammer can be effective and accurate. Practicing on a spare rusty bolt is a good idea. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
