Posted by RustyFarmall on September 09, 2007 at 15:09:55 from (66.43.253.55):
In Reply to: Rusted bolts posted by Mike CA on September 09, 2007 at 11:58:58:
Heat is the easiest and safest, but be careful or you will end up damaging the headlamp. Also, do not attempt to hold the headlamp while turning that nut, or you will end up turning the bolt inside of the lamp housing and then you just wrecked a perfectly good set of lights.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
