Re: How screwed am I?
Posted by riverbend on September 09, 2007 at 19:58:48 from (208.160.34.238):
In Reply to: How screwed am I? posted by Mike CA on September 09, 2007 at 19:34:01:
This is the perfect time to buy yourself a little wire feed welder. Weld a nut on the broken bolt and turn it out while it is still warm. Then after you have a little practice, weld a nut onto the busted stud. It will come right out too.
If your budget won't afford a welder right now, check with one of your neighbors. If it will, buy one a little better than the cheapest.
Won't you need a complete gasket set ?
Greg
