Re: How screwed am I?
Posted by banjo on September 09, 2007 at 20:40:03 from (65.67.203.65):
In Reply to: Re: How screwed am I? posted by Mike CA on September 09, 2007 at 20:20:27:
Even if it is broke off flush you can still weld it to a nut. just center the nut with a pair of pliers and weld threw the middle of the nut building it up. That is where the wire welder comes in real handy. Alot easier then trying to use a stick welder inside a small nut.
Easy outs are seldom easy. I'd rather center punch it and use a drill bit to drill most of it out.As long as you dont go too big and go real slow the tap will probably get the rest of it out.
