Re: How screwed am I?
Posted by Hayfarmer on September 09, 2007 at 20:44:52 from (66.243.235.184):
In Reply to: How screwed am I? posted by Mike CA on September 09, 2007 at 19:34:01:
Mike, I have had good luck drilling the bolt and taping out the hole. If you drill then use and easy out, be really careful because if you put too much twist on the easy out and it breaks it becomes a bigger problem. Other guys talk about using reverse drill bits, I haven't had much luck there. I try to start drilling as near the center of the bolt as possible with a small drill then work up with larger bits, I usually have not had to heat the bolt. When you get near the size of the bolt you can sometimes chip out the sides. Not a fun job at all but also not uncommon.
