Posted by PaulW_NJ on September 09, 2007 at 20:48:10 from (70.111.186.38):
In Reply to: Re: How screwed am I? posted by PaulW_NJ on September 09, 2007 at 20:39:32:
The trick is to weld a flat washer to the broken bolt first, and then weld a nut to the washer. Any chance of getting a couple quick weld contacts from the inside of the flat washer to the bolt? Then weld a nut to that. Sometimes the heat of welding on the washer/nut does most of the work in freeing it up.
If not, you may have no choice but to drill it out using successively larger bits till you get close to threads. And then try to work the rest out with a punch. Hard part for me is centerpunching the exact center before drilling.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
