Re: Little genius pough parts
Posted by Hugh MacKay on September 10, 2007 at 02:44:50 from (216.208.58.164):
In Reply to: Little genius pough parts posted by J. Klein Rot on September 09, 2007 at 07:46:48:
J Klein Rot: The coulters will be quite easy. Plow bottoms another matter as there are about 6-10 different bottoms the No. 8 Little Genius could have been equipped with. If you could find part numbers off frog, moldboard and share, it will speed this up for you, no matter where you buy. George is right CaseIH may have them, however I suspect Paul's solution may be the answer.
There are also a few foundries in the mid west corn belt manufacturing plow wear parts. I don't have the names, but have seen them mentioned here on YT several times. There is also a Foundry in Quebec making plow wear parts. I've not dealt with them directly, only through local retailers, both here in SW ON and from NS.
