Re: Farmall B - carb
Posted by teddy52food on September 10, 2007 at 10:42:12 from (204.73.107.177):
In Reply to: Re: Farmall B - carb posted by Dave H (MI) on September 10, 2007 at 10:31:43:
White smoke is usually water. Sounds like it is slightly flooded if you have to crank for a while with the choke open to get it to fire. The black smoke is too much fuel. Take it apart and make sure the seat is in tight with a new (good) gasket. Check the float level you may have to lower it a bit.
