Re: Farmall B - carb
Posted by pete7 on September 10, 2007 at 16:01:28 from (72.65.39.31):
In Reply to: Farmall B - carb posted by Dave H (MI) on September 10, 2007 at 08:06:30:
Hi Dave....I'm wondering if the idle speed is set to high. With a high idle speed, the idle adjustment will not show much effect because the main jet has already kicked in. If you are seeing black smoke at idle that shows a rich fuel mixture. (ie to much gas or not enough air)
Pete
