Re: Push rod tubes
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by p on February 16, 2000 at 13:46:00 from (209.186.155.141):
In Reply to: Push rod tubes posted by Bill on February 16, 2000 at 06:18:57:
I don't know about the H but my Super A has a pressure fed system that enters on the center bolt that holds the rocker arm assembly on. The oil pressurizes the rockers and that is how the assembly is oiled. It is not a hydraulic lifter like a small block chevy has but they are mechanical and therefore do not send the oil up the shaft of the pushrod. Also an engine (car) rebuilder friend of mine was impressed at this setup because this is how many modern import cars setup the rocker assembly.
Post A Followup
: Re: Re: Push rod tubes
