Posted by Red Dave on September 11, 2007 at 12:52:18 from (66.216.141.163):
In Reply to: Re: Hey Rusty Farmall posted by Janicholson on September 11, 2007 at 12:43:12:
Thanks Jim, I knew that part. The part I'm unsure of is just how much difference it really makes using resistor vs non resistor plugs on a magneto ignition. Both will work. I've used both on a magneto and I think the 3116's (non-resistor) run a little better than the 386/388's (resistor). But I have no objective data to back that up, just my very subjective ear.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
