Re: Autolite plugs
Posted by in on September 11, 2007 at 16:10:55 from (64.184.4.12):
In Reply to: Re: Autolite plugs posted by Red Dave on September 11, 2007 at 07:59:33:
I run 386's with electrnic ignition in my SM haven't fouled a plug in 7 years, hot coil on 12 volt.
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
