Re: Re: Re: Re: Super A water pump ?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by ddg on February 16, 2000 at 16:07:24 from (152.163.204.57):
In Reply to: Re: Re: Re: Super A water pump ? posted by Stan(VA). on February 16, 2000 at 05:15:04:
You also need the head gasket with the SMALL water passages, to give the water pump some resistance, The theric syphon type head gasket has 1/2" holes, the water pump head gasket has about 1/8" holes.(My Super A has no pump, and always ran a little warm. I pulled the head & found a newer gasket under it, replaced it with the one with larger holes, and it runs cooler now).......DDG
Post A Followup
: Re: Re: Re: Re: Re: Super A water pump ?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
