Posted by Bob Kerr on September 11, 2007 at 20:51:53 from (64.12.116.73):
In Reply to: Sorta OT posted by Karl Hamson on September 11, 2007 at 18:50:11:
I have a 24 Oldsmobile 6cyl with a Delco (not Delco Remy)igniton system. My Olds has a 60s chevy distributor on it at the time being with the advance welded and the vacuum removed so the spark lever works right, but I have the original Delco,but the pot metal has failed on it. It has a long condenser under the cap. If the new condenser is under the cap and out of sight, it shouldn't make much difference until you find a good correct condenser.I need a Delco distributor for My Olds, but one from a 24 Buick is the exact same. My Take on electronic ignition for a low compression, low RPM engine is that it is just not needed at all and is a waste of money. As for reliability, points are points, they are just a switch. the newer condensers are better than the NOS or originals as the materials are not as prone to breakdown from age. I would just use your old points and new condenser and a new 6v coil. My car is a touring and the original coil mounted under the dash. I am not sure where they are mounted on enclosed cars, but I bet they are under dash also to keep them out of the heat as they couldn't take much. The old ones back then were not often oil filled and the insulation laquer on the windings would cook easily.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
