10-20 pto revisited
Posted by russ hamm on September 12, 2007 at 10:30:33 from (63.245.179.200):
Below bob was absolutely right. I have two pto systems for 10-20's and they don't show up everywhere, but not really rare. We have used one on a binder, which also uses a different drawbar setup. If you look in the pto binder manuals you can see illustrations of these, sometimes even made for different brands of tractors. The extension setup has an enormous shield used on 10-20 and 15-30. These were made universal with different holes to fit both platforms. The left hand screw in u-joint bob mentioned actually had an adapter for the splined shaft, you will see many of those on w-30's and they fit all the early standard tread pto's.
