Re: IH 140 with belly mount sickle mower lift mount
Posted by chadd on September 12, 2007 at 11:38:04 from (155.92.31.230):
In Reply to: IH 140 with belly mount sickle mower lift mount posted by davida on September 12, 2007 at 10:50:11:
Every spring I do the maintenance on a 130 International with a mounted sickle mower, which is probably very similar to the set-up you have. Unfortunately, it isn't here, and I don't have a picture of it. Attached to the short arm (the one with the two bolts in it) was a cable which ran down the left side of the tractor to a pulley down by the bar that mounts down the tractor's centerline. From there, it runs to a cast-iron piece that looks like a quarter of a pulley; which is mounted onto the head of the mower (the part where the pto shaft goes into the mower). It follows that curved groove and then bolts into the far end of it. The arm on the right side had 1 or two chains hanging down that were bolted to the frame of the mower about halfway between the bar down the tractor's centerline (that acts like a hinge) and the mower head itself. There were also two large springs that were used to dampen shock loading to the frame and the arm. There was also a small rod that went from the clutch housing of the tractor to the mower to prevent strain on it while transporting it down the road that was disconnected when it was used. During use, the rod simply hung from the tractor. Sorry I can't be more help.
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
