Not Exactly
Posted by Andy Martin on September 12, 2007 at 12:57:40 from (63.123.95.201):
In Reply to: Re: how much power should these lights draw? posted by Pappy on September 11, 2007 at 22:07:17:
Not exactly, what is true is that volts divided by ohms will give you amps. If you double the voltage you also double the amperage, that is why 12v will burn out a 6v bulb.
An incandescent bulb does not have fixed wattage, only fixed resistance. A 30w bulb will draw 5 amps at 6v, but that will rise proportionally with voltage.
