Re: 230 no oil dip stick
Posted by Janicholson on September 12, 2007 at 19:28:56 from (66.173.50.77):
In Reply to: 230 no oil dip stick posted by Russell Pinyan on September 12, 2007 at 18:31:35:
Common finding on Farmalls. The top little Cock is the high oil mark. open it and fill until a bit of oil comes out. The lower one is a broken off (or boogered up copy of the top one. (the engine block may be from a earlier tractor) The bottom Cock was to check if it was more than a quart low, (running with the level between the cocks is correct) replacement cocks can be found, Here maybe, at IH for sure, and from many others OEM maybe. JimN
