Georgeky
Posted by Larry in GA. on September 12, 2007 at 19:29:43 from (216.96.45.94):
George
There was one fast hitch at the auction today A 300TA With some of the best sheet metal that I have seen on an un-restored tractor. It had a 3 bottom plow the fast hitch draw bar a fast hitch to three point rig and they throw in a 6 foot pull type bush hog all for $2550. I have trouble posting pictures here so I will up load them to photobucket and post the link here when I get done. there was also several 400TA's and 450TA's all with single front wheels there. They were not fast hitch and not in that good of shape. There was one 140 with a full set of cultivator in real good shape that sold for $3100.
Larry
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
