Posted by karl f on September 12, 2007 at 23:04:42 from (172.163.175.179):
ex highway mower...this tractor has no hydraulic remote valves. will the pre case ih type bolt up the same as the case ih type (it should be the bosch valves)? trying to broaden the used parts source if it's possible. it doesnt even have the "plate" to attatch valves to. still has the 3pt lift arms/cylinder. you should see the power beyond on this one! right outta the mcv! are there any aftermarket valve systems that would happen to attach in the factory way? t i s c o shows some stackable valve assemblies requiring plates on each end, similar in design to the older ih valves i'm familiar with, but i'm not sure if they share more than the concept. sure do not see many of these in salvage yards! thanks karl f
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
