The H uses the original gauge plate along with the adaptor and you have to drill the mounting holes in your plate.
You've really got to eyeball that wedge and make sure it is mounted so that the torque motor shaft will align with the hole in the radiator for the steering shaft. Get it wrong and that front shaft will bind up going thru the radiator.
It's "wacky" and ends up being about 5 to 10 degrees off from "straight up and down".
Also, be careful when you shorten your steering shaft allowing for the motor and those trunions. Again, the measurements have to be just about right on.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
