Re: reversing the fan blades on a 574
Posted by johns48jdb on September 13, 2007 at 03:45:53 from (205.188.116.73):
In Reply to: Re: reversing the fan blades on a 574 posted by chadd on September 12, 2007 at 14:50:26:
interesting thought chadd, i"m in a hard spot either way i go. i have a home made real heavy duty radiator guard on the tractor and then once past it you have to remove the grill and then swing the oil cooler out of the way. then it would be ease to blow the radiator out, if you turned the tractor off and if its hot i don"t like to do that. oh look, there i am, between the rock and hard place, again. thanks for the input.
