well got the injector out, now what, how do you do a compression test on the cylinder, there appears to be something down inside the injector hole, can i turn the engine over with the injector out, will that hurt anything??
if i screw the injector onto the fuel line coming form the pump should the injector spray like if it was installed in the tractor so I can see if there is fuel coming through it and if so what should it look lik eif it does spray and is working properly?? the end of the injector is a little bit egg shaped is that normal? kinda has a little bit of like carbon/black stuff on the end of it
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
