Posted by Unreserved dick on September 13, 2007 at 16:44:26 from (4.228.126.150):
In Reply to: 350 Hi Utility posted by Pat in Wisconsin on September 13, 2007 at 10:51:45:
Pat:
Brakes are straightforward, you should be safe just going at them without any manual.
Hydraulic filter is located inside the reservoir, under the seat. You have to pick the reservoir cover STRAIGHT up to get at it or you'll wreck the filter. The cover is heavy, so your best bet is to have some good strong help and a plan for setting the cover down somewhere (on a couple of 4x4s works) if you decide to go after the filter. Replacement fluid is Hytran, available at your IH dealer (5 gal. should do the entire system including the loader). Drain for the hydraulic reservoir is a plug under the hitch cylinder bracket. If you have factory power steering, I think that's where the return line from the steering column taps into the reservoir.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
