Re: No forward move for the cub
Posted by Haas on September 13, 2007 at 18:09:20 from (12.65.42.185):
In Reply to: No forward move for the cub posted by steve robinson on September 12, 2007 at 17:22:16:
The Cub shifter is different than the larger tractors. The end of the shifter is a sphere (ball), not rectangular like on the larger tractors. So building up the corners with weld does not apply. Whatever the problem, it should be obvious when you pull off the cover and shifter.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
