Re: Super A Cam and Gov. Gears
Posted by Hobo,NC on September 13, 2007 at 18:47:24 from (67.141.255.231):
In Reply to: Super A Cam and Gov. Gears posted by eye4iron on September 13, 2007 at 07:41:11:
First, I have only tried this on a 123 engine in a 100, the cam gear can B removed. Drill and tap the gear for a puller, a harmonic balancer type will work. After its off drill and tap the center of the cam, install a stud and use washers to pull the gear back on. I usualy tap 7/16 course threads. all the drilling and tap'n is rite EZ on the cam and gear. I have done right many on sideways mounted engines in cars 2.5 GM's no problem. I still have the gear off the 123, it came off right EZ and the new'n went back on EZ'er than you would think. NO I would not remove the cam less I were going to do a rebuild.
