Posted by Bob M on September 14, 2007 at 11:52:54 from (151.190.254.108):
In Reply to: Ammeter wiring posted by Farm130 on September 14, 2007 at 11:15:36:
Seems there's no standard for ammeter terminal designation - at least for the old stuff. Sometimes there's a red or white paint dot next to one terminal. Or you'll find "+" stamped near one terminal. But my experience is generally there's no marking whatsoever.
How to connect? Easiest way is to hook it up and try it! Then if the ammeter indicates discharge when you turn on the lights or ignition, it's wired correctly.
However if the ammeter indicates charge when you turn on the lights/ign, simply swap the wires between the two ammeter posts and you'll be set.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
