Posted by Haas on September 14, 2007 at 13:54:39 from (12.65.78.83):
In Reply to: Belt pully seals posted by jjamna on September 13, 2007 at 19:36:48:
You may need to use a shop press and bearing separator to remove the gear and bearings from the pulley shaft. You may be able to drive them off, but I took the assembly to a shop and had them pressed off and back on. There is not a gasket on the flange that mounts the assembly to the housing. There are shims there to set the gear lash. Be sure you put the shims back like they came out and clean them and the mounting surfaces. Make sure they are absolutely clean when you reassemble but even then, you may have some seepage of gear oil due to there being no gasket, only metal shims. When it's back together, put a pint of gear oil in the fill hole on the belt pulley housing. The transmission lubes the belt pulley bearings, but it takes a while for the oil to sling up there, so you need to add some for initial lube. Oil circulates from the transmission to the belt pulley housing and overflows back to the transmission.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
