Re: Crankshaft Weight Removal IH 756
Posted by Owen Aaland on September 14, 2007 at 18:15:42 from (65.161.86.86):
In Reply to: Crankshaft Weight Removal IH 756 posted by BWNOK on September 14, 2007 at 07:43:56:
The tool is a 14mm triple square driver. Mine has "Hazet 990" for name and part number, made in Germany. I got it about twenty-five years ago from Owatana Tool Company. They were the suppliers for IH special tools. In recent years I have seen some of these drivers listed in Snap-On or Mac tool catalogs, but I do not know if they go as large as 14mm.
The IH repair manual says to use a 3/8" drive extention to remove the bolts. I always found that I destroyed a few bolts every time I tried doing it that way, so I bought the special tool. It may work better if one were to grind the end of the extension flat before trying to loosen the bolts.
