Re: Radiator Mounting Stud for Farmall H
Posted by Murray M on September 14, 2007 at 18:19:59 from (71.7.35.30):
In Reply to: Re: Radiator Mounting Stud for Farmall H posted by dcw on September 14, 2007 at 18:17:36:
Thanks for the input. I ended up using the 7/16th threaded rod and that worked just fine.
