Re: Help! Diesel overflow!
Posted by Owen Aaland on September 14, 2007 at 20:35:52 from (65.161.86.86):
In Reply to: Re: Help! Diesel overflow! posted by Bob on September 13, 2007 at 21:11:40:
There are two tools for replacing the seals. One is a bullet shaped tube that fits over the drive shaft so you can slide the seals over this tube and drop them into the correct groove. The other one is used to compress the outside lip of the rear seal so that it starts into the pump housing without being damaged.
