Re: Snow Removal with Farmall M
Posted by flashback on September 15, 2007 at 07:25:08 from (216.119.6.77):
In Reply to: Snow Removal with Farmall M posted by plowindayz on September 15, 2007 at 06:11:00:
I would prefer to use a loader with a clam shell bucket if possible. Turning around on an M is not only hard on the back but for me would be slightly dangerous as my legs are not quite long enough to clutch and brake when turning around. A good loader bucket can be used to push and then lift the snow out of the way Can also be used to pull snow out of the way and then loaded in the bucket.
