Re: Dang'it!!!!!!!!!!!!! :(
Posted by rich4 on September 15, 2007 at 09:23:08 from (74.60.110.90):
In Reply to: Dang'it!!!!!!!!!!!!! :( posted by Patrick Martin on September 15, 2007 at 03:18:23:
Get an override clutch on the PTO. Also start out the PTO at lower RPM. The override clutch allows you to start up the mower first, then put it in gear. Also critical that the blades are sharp. It should pick it up OK, but may need extra front end weights for better steering. In tall grass 1st gear a must.
One last thing, does the mower turn over by hand easily. If not could be a mower gearbox problem.
