Re: H Lift-All difficult to lower with load on
Posted by Steven f/AZ on September 15, 2007 at 15:24:37 from (24.121.167.138):
In Reply to: H Lift-All difficult to lower with load on posted by Illinois Farmall on September 15, 2007 at 12:35:20:
Plumb in a spool valve and you will be much happier. The valve will allow you much better accurate control for those small adjustments.
Get hydraulic pressure from the liftall to plumb to the "in" port like this:
third party image
Tie the lever back like this (sorry the wire was just temporary):
third party image
And put the return "out" port of the valve to the liftall drain like this:
third party image
Finally, hook up the hoses from the valve to your loader, or to remotes like this:
third party image
