Hi Jerry, I just use a box end wrench, can only turn a fraction at a time. Just wait until you try to put the washers and nut back on.
Thru the timing cover hole, DO NOT LOOSEN or REMOVE the 3 cap screws on the timing gear adjustment. Only remove the large nut on the injection pump drive shaft. Be sure to accurately mark the location of the injection pump to the mounting plate so when you reinstall it the timing will be correct. Use an awl or something to put a scratch line on both.
When you reinstall the injection pump and the tractor will not start after bleeding & priming then the pump could be 180 degrees out of time so you will have to remove the injection pump again turn the shaft 1 rotation and reinstall. The injection pump only turns at 1/2 the speed of the engine so can be 180 degrees out of time when reinstalled.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
