The noise is comeing from the planetary gears in the pto unit. Some noise is normal with wear. Be sure to check the oil level in the pto unit. It filled seperate from the rear end. Has a check plug on the left side of the pto houseing. If you have a fast hitch will have to remove top cyl pin & swing the cyl back to get to the plug. Fill through the check plug hole, takes 2 qts. Use Hy-Tran same as rear end & trans.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
