Re: Super C Industrial
Posted by Hugh MacKay on September 16, 2007 at 15:50:33 from (209.226.247.183):
In Reply to: Re: Super C Industrial posted by TimWafer on September 16, 2007 at 15:12:24:
Tim: It is possible to put 240, 340 or 404 hub for pressed steel rims on a SC, however I don't think that happened. The wide front pivot casting bolted to the tractor bolster is either 240, 340 or 404. That casting, although it has the same bolt pattern is quite different on the SC. Further to this SC did not have the wish bone brace back to the clutch housing. 240, 340 and 404 did and it was exactly same as on your tractor. I'm calling it a 240, 340 or 404 wide front. There was yellow primer used on 40 series tractors.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
