Re: T-4 thru TD-5
Posted by td5doug on September 16, 2007 at 18:42:21 from (207.200.149.42):
In Reply to: T-4 thru TD-5 posted by Quebec Red on September 16, 2007 at 14:35:40:
The model/serial # plate will be on the RH side of the flywheel housing above where the starter mounts.... if its still there, alot were destroyed from battery acid as the batteries are located above it.
