Re: Question about spark plugs
Posted by Bob Kerr on September 16, 2007 at 20:00:12 from (64.12.116.73):
In Reply to: Question about spark plugs posted by Mike CA on September 16, 2007 at 17:09:27:
Mike, like the others said about the socket, 7/8 will do it. But, if the center electrode has square edges the old plugs are most likely fine to use. As long as the plugs aren"t wet from oil soaking or flooding they are ok to use in the tractor engines. Save the money. I have had my f-12 since 1999 and it has the same plugs in it when I bought it and they were old then, it runs like a champ! Spend the money on carb cleaner and a wire brush to clean the plugs. You will need the wire brush down the road, trust me!
