Re: stupid motor
Posted by MN Scott on September 17, 2007 at 07:12:42 from (206.9.216.48):
In Reply to: stupid motor posted by smdv806 on September 16, 2007 at 19:01:59:
If everything checks out with the distributor check your intake manifold for vaccum leaks, very common to that engine. Spray carb cleaner were the manifold contacts the head. Rpm should not change. Also is your heat riser valve on the manifold working? The thermostatic spring broke on my 706 once and it would stumble like yours does. Replaced the spring and all was well again.
