Posted by chadd on September 17, 2007 at 09:29:18 from (155.92.32.233):
In Reply to: stupid motor posted by smdv806 on September 16, 2007 at 19:01:59:
The advance mechanism on this tractor is mechanical and utilizes 2 weights that are attached to the breaker shaft (which slips over the distributor shaft) and precision springs. As the rpm of the shaft increases, the centrifugal force on the weights increases. This causes the spring to lengthen and the advance curve to change correspondingly. Problems with the advance system will cause backfiring or kick-back at start up or hard starting depending on where it is stuck. You need to remove the plate behind the points to be able to see the weights. More than likely a spring broke or the peg wore or broke. Also, you cannot replace the springs separately, so you have to buy two of them, and don't try getting ones from a junk yard, because those springs will be in just as bad of shape.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
